Random jeep part game
I'm having a harder time coming up with parts now.
Try this one:
Wiper pivot gasket
This one is up because it looks interesting. Yep. it's getting a litte tough not to be too obvious.
Oil bath air cleaner for an old Willys?
Time for a trick question!:cool: Another older Willys/Jeep. What is this called.
Looks like a drive shaft but I think they called them propeller shafts back then.
Great job :notworthy:. I thought it was interesting that it was called that, but makes sense. When I first came across the name I thought it was from a Ford GPA Seep like this :cool:.
So here is what I think is a small parts tough one, although I am not real familiar with the older ones. But let's see.....
The above is a pedal draft pad set. Something to do with the pedals where they go into the firewall? 59-71 CJ5 's and lots of other older Jeeps have as well.
Ok guys, this is probably very obvious...
Alright, its a washer... But where is it from?
I dropped off a 360 block, heads, and crank at a machine shop and got a box of bolts and small parts back...
Those are the clues...
Oh, and its approximately 1 1/4 inches O.D.
My guess is a Cam shaft thrust washer behind the cam drive gear.
Good guess, but the engine was given to them in 4 distinct pieces, already disassembled...
1. block
2. heads (2)
3. crank
4. box of pistons on connecting rods
that was all I gave them
(BTW: you're scarring me.... is there supposed to be a thrust washer behind the gear!!! ) I just put on the timing set 2 days ago !
I can't remember for sure, I was just guessing.
Kinda looks like a valve spring shim.
Nice call CJ ! It sure does look like that...
I'm gonna give the heads a once over and see if I can tell if one spring is missing a shim.
Machine shop might hear about this, especially since it was in a small box of bolts, etc they took off the block and heads.
3 weeks, 4 days, 2 hours, 24 minutes, 1 second
