Random jeep part game
Wiper pivot gasket
Time for a trick question!:cool: Another older Willys/Jeep. What is this called.
Looks like a drive shaft but I think they called them propeller shafts back then.
The above is a pedal draft pad set. Something to do with the pedals where they go into the firewall? 59-71 CJ5 's and lots of other older Jeeps have as well.
My guess is a Cam shaft thrust washer behind the cam drive gear.
Good guess, but the engine was given to them in 4 distinct pieces, already disassembled...
1. block
2. heads (2)
3. crank
4. box of pistons on connecting rods
that was all I gave them
(BTW: you're scarring me.... is there supposed to be a thrust washer behind the gear!!! ) I just put on the timing set 2 days ago !
I can't remember for sure, I was just guessing.
Kinda looks like a valve spring shim.
Nice call CJ ! It sure does look like that...
I'm gonna give the heads a once over and see if I can tell if one spring is missing a shim.
Machine shop might hear about this, especially since it was in a small box of bolts, etc they took off the block and heads.
$100.00
  50.0%
