Random jeep part game
That's the first WHITE valve stem seal I think I've ever seen!
To get it to go on the ball end you could split it in two halves and hold it together with a snap ring or even an O ring.
I like that. Even make it from two independent rectangular bars screwed together for turning, and turn a pair of o-ring grooves in 'em to keep 'em clamshelled together during assembly.
Yep- and they will wind up where they belong someday- what a PITA:D
A valve stem seal? This one went right by me. please explain.:confused:
I bought valve seals for my AMC 304 6 mos. ago and they are still in the box- they are a pain in the kiester to change out so I've been sitting on them- thought it was a good part for the game tho.:)
its a seal that stops oil from leaking past your valves down into your cylinder, it goes in/under your valve springs the valve stem goes through the hole in theseal
I was trying to make this part of a tire valve stem.:bang::bang::bang::laugh:
All I want for my birthday is a clue.
Your guna let that one slide? Your being to nice tonight.:D
Hey what's all this :dung:? Where's the candy?
What is it?
Let the new guys have a go fellers.
Well your Jeep wouldn't be 1/2 as fun without it. :)
What is it?
Two days later... Now the answers are open to all!
What picture - and why does the gear on the left look fubared? Is it (the gear fubar)? If yes why? If not, why not?
Well, it certainly ain't gonna' mesh with the gear in the upper left (above it) if ya try & shift the thing into 4, now, is it? But that's because the front output shaft ain't there, right?
That's pretty close... you're right next to the correct answer... :)
One more try. A Dana 20 showing the front output shaft at the bottom right of photo. It looks like the Intermediate shaft is toast and that's why the Intermediate gear is out of whack.
