Rear Corners
Rear Corners
007
Crazy Sr. Respected Jeeper
Reno, NV
1977 CJ-7 Renegade (Daisy Jane), Levis trim, 304, TH400, BW1339 (MM), D30/Auburn Max, AMC20/Detroit/G2's, 4.88's, 33" BFG MT KM2's, Edelbrock Performer intake, Holley Sniper 4bbl EFI, MSD6, MSD ProBillet distributor, OME shocks, 4" ProComp lift.
I bought a YJ tub and want to replace the corners with CJ corners for fuel, etc. Does anyone sell these with the holes / cutouts already done?
I'm just looking for the replacement panel with holes etc. not a cover.
Well I did not look I just threw it out there assuming they did. My Bad :D
Instead of replacing both corners don't you think it would easier to just cut a hole on the right side and weld up the hole on the left side?
I picked up a Cj before that had a YJ tub on it and they just cut the hole on the passenger side and used a tag holder I thing from a TJ. Ic covered the YJ hole perfectly.
Thank you folks... I could do the hole myself, but the tub I bought needs corners anyway so I just figured I'd try to get them as close to ready as possible.
I appreciate it!
