Diff Rear Differential Cover Screws
Differentials
CJ7Simon
Bronze Supporter
Richmond Virginia
83 CJ7, 258, T5, D300, D30, AMC/JEEP TRAC-LOK
My CJ7 has an AMC/Jeep Trac-Lok rear differential.
I'm hoping to hear from someone who has been successful in removing the cover bolts on a similar diff. After several weeks of dealing with and finally loosening 10 of the 12 Torx bolts, two (upper) bolts remain. Each one is now stripped so the T40 torx bit sockets are useless.
Any ideas? Thanks!
Simon
Jack it up. Support the frame so that the diff hangs low. Weld a bolt on to the head. Then use a regular 6 point socket.
I use this method for pretty much every torx bolt that strips.
If you don't have a welder. Use the same process except grind the head off. (This will destroy your diff cover. But makes a perfect time to upgrade) Remove the cover grab the remaining bolt with a pair of vise grips and work them out.
Then clean everything thoroughly install new cover, 6 point bolts, (I use stainless) fluid etc. Drive enjoy.
P.S. if you buy a new cover buy a heavy iron one for off roading and they typically come with a drain port.
As a secondary way, grind the heads off. Drill a hole and use an extractor.
Screw extractor -->> (Link)-> Google Search -<
Only problem is the top two bolts leave you almost zero room between the diff and gas tank. Most likely can't get a drill in there
Worse case scenario if you need help I'm only a few hours north of you in Maryland
One that fits. I believe they are 5/16-18
Thanks for the kind offer! I've had no many worse case scenarios since I got this Jeep, you'd have to stay several weeks!! It's lucky I enjoy a challenge!
Just to finish this thread, I persevered and was able to fully remove 11 of the 12 bolts. I had to grind of the head of the 12th. I had to order 5/16"-18 flanged hex head bolts from Bolt Depot and expect to finish this cover removal in about a week. Let's hope the interior components are in fair to good condition because I doubt anyone has looked in there since 1983!!
Thanks for all your help and suggestions.
Have a look at the bolts around the rollbar area. That’s an area under the rollbar that can get bad.
Glad you're working things out. Keep us updated... :chug:
I would wipe out what I could, then a good cleaning solvent.
$20.00
  10.0%
