Hi,
I was wondering if there I can replace the unit that houses the three bulbs in the rear tail light unit or do I have to buy a whole new turn signal light. The blinker unit broke in half and I really don’t like the rust al all. Thank you for any and all help.
The taillight assemblies are pretty easy to find on Amazon or Ebay. If you don't mind doing aftermarket, you can pick up pair for less then $100. One thing I would watch out for is what you're mounting into. With the taillight bieng that rusted, I'm sure the back of the corner panel is also seriously rusted. A good idea is to reach back there and sand off all the rust and debris around those holes, so you have a solid electrical ground for the bolts. Good Luck!
When I replaced my tail lights, I ran a separate ground wire to each and connected those grounds to the same mounting point as the fuel sending unit ground wire. Now the lights no longer rely on a mounting bolt to the body panel for a ground connection. I also used this mounting point for the ground connection in my trailer light plug as well.
