Rebuild Shocker - Water wasted tranny & transfer Case
RustyBucket
Hello,
I bought what seemed like a cool project off of a co-worker. It's 1957 Willy's CJ5 . The only good thing about it is that is has a great running 80's AMC 258 i6 / 4.2l liter straight 6 in it. I've had to replace the entire rear brake assembly including lines. Took it for a spin up the street today, and the Tranny sounded terrible (plus I can't tell if the Transfer Case is in 4wd High or Low. I went ahead and checked the fill plugs on the Transmission and the Transfer Case . I stuck my finger in the Transmission filler hole and got some Hot Chocolate out of it. I attempted to unscrew the Transfer Case Filler screw, and a Latte' came spurting out of it. The ENTIRE transfer case was filled with the paint like substance
I assume this means that there's water in the Transfer Case ? What should I do?!?
To add to that, some previous ding-dong welded a skid plate to the underside of both of the Trannies and I'm in the midst of trying to cut it off with my sawzall. I want to take the bottom plate off of the Dana 300 to see if there's any rust in there with that Peanut Butter Milkshake.
I'm on my 2nd beer this is so frustrating!!
:ww:
