Remote starter
Remote starter
Germy
Full Time Jeeper
Cincinnati, Ohio
1971 dodge dart built 318
How do I hook up the trigger on the starter to do compression test. Pos battery to starter connection? Tried, nothin, wire got warm. Do I need to disconnect lead from starter?
Positive to small 'S' terminal on the solenoid. If the terminal is not marked justry them both, one energizes the coil and one triggers the starter.
Thank you!!!!
Didn't do it yet, but the symptoms are backfire at high rpms, a prominent miss sound. There is a mild cam, but this is definitely a shake and rhythmic miss. I need to know if its something easy up top or if it is deeper.
Took intake off and re sealed to no avail. I need to go out and see what the compression readings are
I hope not, but it is possible that your camshaft could be out of time with the crank. I had to correct this once in a vehicle where I had changed camshafts and it required a 4 degree advance in the cam timing. There are kits available to do this with different degrees of adjustment. It is done by installing an offset in the cam timing chain gear locater.
Here is some info the left side, cylinders 2,4,8 were 140 psi, 6 was 130
Right side 1,3,5 125 psi , 7 115 psi
Cam or head gasket?
Sent from my iPad using Tapatalk HD
Doesn't sound like the cam or both banks would be off. Did you use a degree wheel when you installed it?
Could possibly be the head gasket, but I doubt that the rings have sealed in good yet, so :confused:
What do the plugs look like?
I forgot to number them. I'll take a pic though. Hei not sparking one maybe
I'm thinking I'm going to be doing a head gasket tomorrow. I just re installed the intake with that Indian stuff, I simply am dreading this
looks like it running to rich to me.
I may have been from the richness if idle screws, they were almost all the way out before adjustment. They are about 1 1/2 out
New valley pan and head, valve cover gasket ordered. Tomorrow is go time.
Thanks! Apple is usually pretty reasonable with their products. I'm going to hunt down that leak once the engine is warm, that's when it puddles
