Misc. Replacement dash knobs
Scout1067
Old Time Jeeper
Germany
1981 CJ7, 258, T176, D300, D30 front diff, AMC 20 rear diff, Weber Carburetor, BDS 2.5" lift
Anybody use the replacement dash knobs from Rugged Ridge? I wanted to stay stock looking after my rewire this spring and (I know, I know) went with the Crown replacements because I figured how bad can you screw up a simple knob? Apparently the answer is quite easily as the knob for both my heater and windshield wipers are both stripped from the retainer internal to the knob and I am now going redneck and have a pair of slip=lock pliers to turn the knobs because with them I can grip the little metal piece that used to be inside the knob.
These are the ones I am looking at: https://www.summitracing.com/parts/rgg-1142002
I replaced all mine with those
Mine came from RT Off road and are made by Crown, but still night and day better than the plastic
Just watch when you open the package, the set screws tend to wiggle loose in shipment/handling and may be floating around in there
How do I? Oil seal
