Replacing rear main
Germy
Full Time Jeeper
- Cincinnati, Ohio
- 1985 jeep cj7 360 20 rear and 30 front w/warn lockers 5 speed tranny,
1971 dodge dart built 318
Ok, leaking rear main. I read to loosen the bolts on the crank to drop the crank a little. Slide the two pieces in and re torque main bolts. Is it this easy? Anyone have any first hand on a 360? Also want to do pan properly, do you put rtv in corners let dry then install or install wet?
Thanks!!!!!
Thanks!!!!!
