Reviving my CJ from 9 month hibernation
jzak
Old Time Jeeper
Donator
Featured
Pittsboro, NC
1981 CJ5/258 4.2L I6, Tremec T-176 4-speed, Dana 300, Power Steering, Howell Throttle Body Injection System, Warn Locking Hubs, Warn Rock Crawler front/rear bumper with Tire Swing Carrier, Full Roll Cage, Pro Comp ES9000 shocks
Hey Guys!
So my CJ5 has been sitting outside for the past 9 months, never driven. I've been working in Iraq all this year, but i'm coming back in a February, and i wanted to know what are the Do's and Dont's when trying to revive a CJ thats been parked there for so long?
My big concern is the gas in the tank. After 9 months, has it turned into varnish? Do i need to clean out the tank and flush the fuel system?
Any input is really appreciated.
Thanks!
Get in and twist the key... If the battery is dead, either put a charger on it, or jump it. Check the tire pressure, and go for a ride.
Put some snake oil (SeaFoam, etc.) in the gas tank if you think the fuel is getting bad.
My Harley has sat longer than 9 months (although not outside)....
I agree with Hack, twist the key. Mine has sat outside for 6 months at a time with no issues
^^^ You should have no worries. Just get home safe.
Sea Foam and get home safe
I agree with the others, Git in there and gitt'er done.
If you need to let most anything with fuel in it sit for long periods, dump some Sta-bil (SP?) in the tank. It will stabilize the fuel for a long period of time. I imagine it puts a harmless layer of something on top of the fuel keeping air away. Very much like a pool stabilizer.
Go get a really big juicy burger! :D The Jeep will be fine. ;) God I missed that and Blue Bell Ice Cream when I was deployed. :chug:
You might stick a trickle charger on the battery the night before you are going to start it. I don't really like a charger set on full charge if you have time to coax a little energy back into a one that has been inactive for a while. It more than likely isn't needed but after being on a trickle for a couple hours I like to turn the charger up to full charge for a 15 minutes or so, then turn it back down. For some reason the idea of a little electrical shock from time to time during a refresher charging appeals to me.
Did you do any treatment to the gas before you left it? CK ALL fluid levels. If it's super cold. Put a 100 watt bulb under the hood over night, before start attempt.
How full was the tank.
Get a fresh fully charged battery for the start and maybe a spray can of starting fluid.
Best of luck.
Thanks for the feedback guys! Sounds like a trickle charger, some Sea Foam, and an oil change is all i gotta do. Not sure how much gas is in the tank. My dad and Sis drove it from Outer Banks to Raleigh NC shortly after i left. I do know they didn't put any fuel stabilizer when they parked it.
Thanks buddy! Not deployed, just a contractor, but a real American breakfast and a Burger/Beer is the first things I'm getting, when i'm back. :D
As Lumpy said you will need some starting fluid or gas down the carburetor or you might wear the starter out
