Build Thread Reviving "The Bruise" thread
Make up your mind yet? :laugh: Soon we'll all have this great healthcare plan. Id get the lift. :rolleyes:
Last December I had an abscessed tooth, a root canal gone bad. The infection did significant damage to my heart that I have yet to recover from. It almost canceled my trolley pass. A tooth ach CAN KILL YOU! Don’t jack with this get it taken care of ASAP.:eek:
Boy you have a lot of rust excellent post good luck:chug:
Thanks.
Yes I did get all parts off of the spare axles. I still have to tear into the front axle, but everything is out of the back axle.
I'm gonna weld it up with my Hobart 180 Handler (mig). Not gonna heat it up either. We'll see how it goes...
That's why I'm gonna weld it up and test it, if (when) the weld breaks then I've got the good set.:)
I give it to the end of the driveway. if you go slowly.:cool:
Thanks.
No way. That 220 is eating right through those gears. If anything fails it will be the pinion.
OK but I want pictures of the carnage when it comes un put together.:eek:
seriously, I hope it works out for you. :cool:
The added stress from the locked gears will probably spell doom for the pinion. But I gotta learn the hard way:) I'll stick with my 31's until I do the gear swap in the fall & mainly light trails & cruising.
Pics will for sure be posted when or if ther is carnage.
he ain't kiddin i had the same thing happen to me in 05 i spent 10 days in the hosp. then 6 wks on a pic line dumping antibiotics directly into my heart. the infection caused a growth on one of my heart valves i thought i was gonna die at 22. i got the infection from dentist office while i was having a broken tooth surgically removed. don't f around with that :dung: it'll get you
great thread by the way, lookin good
Awesome thread!!! i hope to learn how to weld here soon dads a welder gonna see if he will teach me this summer. you make me want to work on my jeep that much more! i cant wait to move in to my new place with a garage!!! so excited. Im defiantly subscribing to this one!:drool:
That's why I was out for a bit. I got the tooth fixed before everything got too bad, but recently my heart feels like it has a murmer every once in a while. I need to get checked out.
That's a failed case. Not due to welded spider gears :cool: Could happen to anyone.
Lincoln locker gone bad
Don't worry, no ring & pinions were harmed in the making of this thread.:cool:
$150.00
  75.0%
