Build Thread Reviving "The Bruise" thread
That looks really good!!! I have been tossing the idea around of doing that on my 7, and I think you just convinced me it would not look bad at all. Keep up the good work.:chug:
Thanks. It may look a little wierd when it's done due to the 31's. I think it would look more appropriate with larger tires. I will paint it all the same color so that may help. I'm also toying with the idea of bolting a slider/step rail from wheel well to wheel well. Should help with strength and rigidity.
Do you have access to a shear and brake?? If not how did you form the sheet metal??
Looks terrific BTW.:cool:
My dad originally brought home the 2 5'x6.5" pieces from work about 6 years ago. I drilled holes in them and the jeep to rivet them on (and cover up the rust). You can see them in my first post on page 1. So, I took them off, stripped the paint, welded the drilled holes closed using copper as a backer, ground them down, marked where I wanted the bend, took them to a local metal fab shop and we bent them on a hydrolic brake. Guy was real cool and let me work with him. Cost me $8. He was interested in the project I was using them for.
Then I welded the tubes along the bottoms. The welding warped the metal so I had to use a bottle Jack and the underside of my bumper with the rocker on Jack stands to bend it straight again. Was a PITA!
