Electrical Right rear taillight issues
_Fumbles
Recently purchased this CJ7 , stripped it down to the chassis. New Painless wiring harness. Left rear tail light works correctly in all modes as do front lights/TS Right rear tail light not working correctly. I get the parking light when I turn on the headlights, however I do not ever get a brake light, hazard flashing or turn signal. I’ve traced back to the turn signal wire loom at the steering column and the connection/continuity is good to there but I’m not getting any electrical input coming from the fuse block to the turn signal harness connection. I took the fuse block off the firewall and looked for a loose wire connector or a pinched wire but did not see any indications. I’ve checked the fuses and all of my ground connections but to no avail. I’m hoping that someone might be able to help. Is there a hidden fuse somewhere that I’m not seeing?
