ring and pinion exploded
mattp220
Minnesota
Hi everyone, what an awesome forum. Lots of useful tips here. Anyway, last year I bought my first jeep, a 79 CJ7 Renegade with a 360 in it. I bought it to have some fun and also to learn about vehicles. Last fall I was driving it and there was an aweful grinding towards the front. Pulled over, and noticed that the drive shaft had tons of play towards the front diff, later I revealed that the ring and pinion exploded. While i was pulled over i noticed i was leaking lots of Transmission fluid, it was every where. Why would this have happened too? Could the drive shaft have hit the Transmission fluid tank and cracked the gasket? Any help would be great. Thanks
Sounds to me like you were driving down the road in 4WD.
Yeah, were you driving on pavement or other hard surface in 4WD. In the older Jeeps that is an absolute no no.
Is this an auto Transmission ?
Do you have a shackle reversal ?
What were you doing when this happened ?
Please fill out your jeep profile so we know what you have.
I was on pavement when this happened. My jeep is a Quadra-trac, so its always in 4WD. I guess i didn't know i couldnt drive on pavement. What would be the reason for all the Transmission fluid?
So if i wanted to ever drive this jeep on pavement, i would have to replace it with a 2x4 Transfer Case and front locking hubs, right?
Again, Thanks a lot
What does a shackle reversal do? like i said Im kinda new at this stuff.:)
Well, that's a different story now isn't it. It seems like that should have been mentioned at the very beginning and I feel foolish for assuming that your Jeep was not a Quadra-trac. No matter what you've potentially got BIG trouble, good luck with it now.
This is what happens when people don't fill out there profile. I don't know enough about the Quadta-trac to help but I'm with Hedgehog sound like big problems.
QuadraTrac should be fine driving on pavement, even though it is full time 4wd.
That said, it does sound like your front end locking up messed up something else in the drivetrain. Only way to know exactly what happened is to see where your leak is, and determine if it is simply a leak, or if something in the tranny/tcase is messed up.
On the front end, you can probably find a cheap complete front axle and swap the whole thing in cheaper than you can get a new ring/pinion installed. Just somethingto consider. You'll have to make sure the gear ratio in a replacement axle is the same gear ratio you currently have in your rear diff.
I re-read this post this morning and while the QuadraTrac could have been in full-time mode, it doesn't really matter as you have damage somewhere and it's likely related to the front differential (either caused by the diff or QT).
So one most likely caused the other. QT parts are harder do find, but not impossible and depending on the damage a used one with a new chain may be best option.
You'll find some who hate the QuadraTrac , but if used as designed and cared for it's a fine Transfer Case . I have one and wouldn't want anything else - for what "I" do.
