Rochester 2SE carb. Help please
1981CJ5
Edgefield,SC
Stock 1981 CJ-5 with GM 151 ci.
I rebuild and cleaned the carb . the engine will run but only if you mash the accelerator Petal down vigorusly. I think the idle mixture system might be clogged. Any other suggestions? Thanks guys!
Spraying carb cleaner around the base and gaskets of the carb.
This^^^^ also check where the intake meets the head. Its not unheard of for those gaskets to leak
Droooiiddd 2
