Help Rotational Squeak
JackD
Hello from SE Oklahoma! There is a lot knowledge on here and I really need some at this point. Bear with me. 1978 CJ5 , AMC 258 i6 / 4.2l , T-150 , Dana 20 , AMC20 , Dana 30 . Stock no lift. I have replaced damn near everything that rotates and I have this Damn squeak, squeak, squeak from underneath. Before you say "angry sparrows", here's the deal. I jacked up the rear of the jeep, wheels off ground and emplaced jack stands on the tubes, Backed up with 3 ton jack on Differential housing, backed up with bottle jacks under frame....see where I'm going here? safe....moving on. New drum brakes and shoes, spin wheels...no squeak, New Tom Woods drive shaft with new u joints, Did a complete reseal of Dana 20 and T150, new clutch kit. Changed pinion nut and seal, torque 250 ft lbs, all slack removed from yoke and spins smoothly. I start the jeep, place in second gear, 2wd and ease out on the clutch.....squeak, squeak, squeak.....sheeeeiiiitttt I get underneath with shaft, wheels, everything that rotates moving and I can hear the squeaking but can't locate it....I don't know what else to do....Help
