Brakes Rotor Wheel bearing Hub assembly?
Starbrick Jim
Spring Hill KS
83 CJ7, 42 MB
Thanks for the reply. My front is an AMC20 so hopefully it should not matter or make a difference. Should it? I like your solution better than trying to find the assembly that looks like mine.
Jim I'm in the process of doing the same to my 77 CJ5 . The assembly is two pieces you just have to pound out the studs and they will separate.
Thank you very much for the direction. Well, you were correct, I did punch out the studs and it came apart. I could have sworn it was one piece as the rust hid it well. Moving on in my new frame up rebuild.
