Build Thread Rough but Ready Renegade
BC CJ
- British Columbia
- Early 1975 CJ 5
304, NP435, AA, D300, D30, D44
Update: E-brake
One of only a few things that didn’t work on this Jeep was the E-brake. As mentioned, fixing it was a priority for me. I was happy to find that it seemed to work fine but was out of adjustment. Well, fixing it turned out to be a bit more involved than simply adjusting it. There were a few issues:
1-The adjuster bolt was topped out; there was no room to tighten the brake due to stretched, old cables (the brake shoe thickness is still good at ¼”). This was easily fixed with a cheesy spacer made of washers and what not.
2-The peddle bracket was cracked and would buckle under the force of pushing on the peddle hard. To remedy this I built a simple brace using 2” metal tube chopped up and bolted on using existing holes in the E-brake bracket. The pic will explain better than I can!
3-The existing routing of the cables allowed for very little down travel of the suspension because the cables looped over a cross member. So I took it all apart and cleaned the components up.
And then re-routed the cables to cross over each other rather than stick to their respective sides as before. By doing it this way the cables are no longer stuck over a cross member and since they travel from the center of the axle out they should hardly move as one side droops and the other raises. I think they will also be fine if both wheels droop… so long as I don’t install revolver shackles or anything like that. A final point is that the angle at which the cables enter the brakes has only changed a bit. Maybe some rubber or plastic sleeves to allow the cables to slide around easier on the rear diff?
So now they are adjusted, I can force as hard as I want on the peddle, and they work – sort of.
I could still turn the drum forward by hand but there was significant resistance however, in the reverse direction I could’t budge it. Now, this is in the air with an open diff… so the other side was turning the opposite way. So in the end I have no idea what component might need attention. I am hoping that once I’m driving the Jeep the brakes will auto-adjust and things will work themselves out (as if anything is that easy!). For now I have a functioning (but not perfect) E-brake.
The other big news is I am finished with undercoat scraping!
Until I get the front fenders off.
Maybe interior next... so much to do!
