Build Thread Rough but Ready Renegade
Sorry MexCJ5, I cant help you.
As for my Jeep: I got a new steering stabilizer installed, adjusted in the steering stops now that the boggers are gone. It should turn a lot sharper! I ordered in new shocks that will increase down travel by 4.5 inches and should be safe for up travel due to the bump stops (I still need to build a spacer for the rear ones). The rear brake hose should be fine but the front ones will need to be longer... so I'll have to wait to instal those 2 shocks. I got some Munroe Sensa Trac shocks comming. They were cheap through our local parts supplier, they are nitrogen charged... i dunno, should be decent shocks.
I've been ticking off my list fast and furious recently but a fair bit to go yet. And one last bit of exciting news: I got it insured and took it for the first round the block drive today! The handling isn't 100% but is far, far better than it was. Everything else seems to work fine. :cool: More test driving to come!
I'm in the middle of a big repair weekend. It started when the brakes began pulling hard to the right. I had to drive home by gearing down as the brakes were only safe to use (lightly) under 20km/h. After checking things out I found that a wheel cylinder is leaking and the fluid got on the drum. Apparently when there is oil or grease on the drum or shoe the brakes will grab hard and lock up. So off to get a brake cylinder...
So then I thought, while I am doing brakes I may as well replace the soft lines with longer ones to accomidate the new, longer shocks I will be installing. Then I thought about the ball joints, they had play in them and should be replaced also. So off to get ball joints...
I used a c-clamp style ball joint press from a rental shop. These things are tricky to get all set up right and even harder to use. I had a breaker bar with a long pipe on it and an axe handle in the knuckle to get enough leverage to do this (not haveing a big enough bench vice). Now I'm tired and sore but they are done and re-installed! The brake cylinder is replaced and everything is cleaned but I am waiting on the new hoses to put it back together.
It was a big, hard job so I am really hoping everything works well once its back together! Fingers crossed! If all is well it'll be time for a test drive, maybe a little dirt road wander, and I'll take some pics. :)
It's funny how one job leads to another and another with Jeeps. Glad to hear you got it handeled. You will be running trails in no time. :)
I'll try to get some pics soon... ramp test with the new tires is a good idea.
Tires are 33x12.5 15
wheels are 8" wide
Lift height I have no idea... i dont think the springs are original and it seems a bit too tall for just the extended shackles I have. I'm going to guess its about 3 or 3.5 inch.
Should be pretty close the 33 inches. The boggers were measuring in at 33.5 (which made sense cause they are 35 new with 3/4" tread so minus that, they are bald, times two, top and bottom, gives 33.5). And the new tires were about half an inch lower.
I dont know why all tire companies cant just make tires that measure the same height as the side wall says :rolleyes: But I think these ones are pretty close.
I dont know when the test drive trip is going to happen. mntwhlr made note of how Jeep projects tend to expand in scope: try a home renovation! Its driving me nuts :bang:
Well your right some of these tires are all over the place in height that's why I asked...........and I know how ya feel just finished adding 1500 sqft , so I'm tired of living in the dust.
Nice job! Jeep looks really good. Glad the handling is worked out. You mentioned you had brake fluid all over the drums. I assume this means there was fluid all over the linings also. You hadn't mentioned that youve replaced them. And if it's still pulling to one side, that may be the issue. Typically, fluid on the linings ruins them, and the shoes need replacing. Don't know that's your problem with your particular project, but it's worth looking into.
Thanks Trucklocker! The linings may very well be ruined. I sanded the :dung: out of them hoping that would clear it up. It seemed to help a lot but maybe it wont last... haven't driven it much yet.
For now I'm going to drive it like it's trying to kill me (very carefully) and inspect the drums again after another drive. We'll see...
This whole episode, plus the wet brake thing, has me thinking about disc conversions for the front. One day. :)
Yeah, I once had a 64 El Camino had the same problem. Replaced the linings, and it worked just like it was supposed to work. After a thorough cleaning of the drums again, that is. Brake parts cleaner is your friend for the metal parts. Just won't likely work on the linings, which tend to absorb the fluid, making their friction unpredictable from one side to the other. Always replace in pairs. Both fronts or both rears, or all four.
Thanks Trucklocker, that sounds like really good advice. That will be my next course of action if these brakes act up again... or after more driving I just dont like what I feel. :chug:
Crazy enough, I just bought a Toledo CJ5 that also rolled of the line Dec. 1974!number 023452. Love what you are doing to yours, The color you chose is the original color for mine.
Crazy enough, I just bought a Toledo CJ-5 that also rolled of the line Dec. 1974!number 023452. Love what you are doing to yours, The color you chose is the original color for mine.
Thats awesome! :chug: Your Jeep is looking good, pretty well equipped already. What kind of plans do you have for it?
$20.00
  10.0%
