Build Thread Rough but Ready Renegade
Love the scenery! Still very jealous down here. If I can get my jeep back together I'm going to run around some back road in northern MN before snow hits.
Good to see you out having fun with your Jeep, nice pics thanks for sharing.
great pics looks like a lot of fun thanks for sharing :chug:
Great pictures. Glad you were able to enjoy another day of driving the Rough but Ready Renegade with your son before the bitter cold sets in for yall up there!
On the last of those trips I blew a wheel bearing. DOH! I drove 25km doing about 25 km/h to get to cell service and called friends until I'd arranged a ride home with the Jeep on a trailer. I'm glad to have great friends!
The wheel bearings have been fixed (properly greased and sealed this time:rolleyes:) but I took the Jeep off the road early this year anyways. The clutch is dodgy, I'm tired of the poor crawl speed of the 3 speed, electrical glitches everywhere, E-brake still stinks, and it's just generally too rickety. So this years' winter work is going to be a lot more extensive but the plan is to be ready for next spring.
In the works:
-NP435 Dana 300 combo
-Re-wire with painless kit
-removing the lower propane tank for more clearance
-new exhaust inside the frame rails
-body work, new body mounts, and more tremclad:dbanana:
-I also picked up a couple more axles to bench build and swap in later. Not sure if I'll get that far this year or what all will go into them but they are another pair or intermediate axles. 44 rear, 30 front. Narrow track.
And thats pretty much up to date now. :)
Just read your entire thread. You've done a great job. Thanks for inspiring me. Where are you located in BC? I have a lot of family spread throughout up there in places including Chilliwack, Vancouver, Nanaimo, and Victoria.:chug:
I'm in Kelowna, in the Okanagan. Lived in Victoria while in university - it's a great town.
Thanks for the compliments! I've learned a ton, still learning a lot as I go. I'm going to know this jeep inside-out by the time I'm done. Which will be great for future maintenance and breakdown; I'll have the right tools and knowledge for the job. It's no work of art like some of the builds on here but it should be a solid, functional Jeep next year.
Just picked up on this thread. First off nice job! Now just my funny 2 cents worth...every see a propane tank explode? Now I can't say that I've ever heard of one in a vehicle do that, but when I was young (70's) we had a railroad car full of propane explode about 4 am. Blew the front door of our house open and we were 3 miles away. Leveled a high school gym. Killed 8 people. I spent 10 years in the fire service and went through special traning for propane tanks. Here a just a few things to keep in mind if ever... When a propane tank leaks the liquid propane turns to a gas very rapidly. This will cause extream cold. So never fill or handle anything leaking propane without proper gloves. If a tank leaks or gets to hot that it vents ( yours should have a pop off valve on it), if fire is envolved, get back and do not try to put the fire out. There is a very precise way to handle this and most of the time with smaller tanks, fire fighters just let them burn out. Just some advice from past experience that nobody else may have said. Good luck and have fun with your Jeep and cudooos to your use of an alternate energy form. Rod :)
Peanut Butter. Thanks for the input. I have some training with propane cylinders from work and yes, I believe in gas form it takes up 274 times more space than in liquid form... very quick expansion can cause major damage. These auto-grade tanks are crazy strong though, the biggest risk is a line cut which causes a slower, more controlled release but I'll get far away if that happens! But even that isn't too likely; the only legal lines are steel braided with neopreme on the inside and rubber around the outside. They are really tough. Set up right I think it is safer than gasoline.
Other GREAT things about propane: I went from valley bottom under 2000 foot elevation strait up and over a 7000 foot mountain pass with NO change in performance. I've stopped on steep slopes for long times and never heard the engine miss a beat. And, its darn near half the cost of gas right now! I love it!
Pete, that is a basic "roof top tent" (google will show you all about it if you havent seen them) the only trick was using exhaust pipe clamps to attch it to the roll bar better than the flat bar it came with. ;)
