Rust Under Roll-on Berliner - What to do?
kenny 84 CJ7
All,
My newest project is to come up with a plan for some of the rust in my tub. Getting close to the winter months I want to have a plant to start working on it. I have a feeling it will put the jeep out of commission for a few weeks.
The problem:
My previous owner decided (in his divine wisdom) to roll-on a bedliner throughout the entire tub of my 84 Jeep CJ7 . At the time of purchase I thought "great, one less thing I will need to do". I feel now I was wrong.
I have now noticed rust stains coming up through some spots on the floor. Also, around the drain plug on the drives side i could see the bed liner cracking and rust underneath. With a little knife I peeled up a small piece of the liner and rust all underneath. The PO rolled on the liner very think is some places and it is beginning to crack there.
It is either one of two things:
1.) The PO didn't know what he was doing when he did the bed liner and improperly prep the tub before painting. i.e. sanding and repairing all rust.
2.) The PO used the bed liner to cover up the rust in order to sell the Jeep. (that would be very mean, it was my first Jeep so I didn't even think rust might be under there)
My Questions:
What should I do here?
I could try and remove the current liner, then fix/replace the rust that is bad. Then have a new liner done professionally. Im not sure how I could remove it. Perhaps a grinder with wire brush. Also, not sure what I will find underneath. I am not made of money. I would hate to start a job and not be able to finish. One thought I have is just forget about it for now and save up enough to replace the tub. Then start on grinding off the current liner. If I find it is too much to tackle, worst comes to worst I just replace the tub all together.
Any thought and suggestions would be really appreciated. Thank you in advance for your help.
-Eoin
The problem:
My Questions:
-Eoin
but sounds like the po thought this bedliner was a solve all problem paint. It is not. Any bed liner requires proper pep of the surface to be covered first. Thus the high cost of having it done. So remove all of it, repair any major rust spots, treat all other rust spots (more later), and then recoat if that is the type of finish you want. You can do it yourself, but don't skimp on the quality of the product. Prep the surface. Remove as much rust as you can, and treat the rest with a fast etch solution that converts rust to zinc phosphate. All surfaces will need to be ruffed up for the paint to stick. Even a new truck bed must be sanded for a bedliner to be properly applied. I got my fast etch solution from Eastwood, and am very happy with the results.
So, I'm doing all of the sanding, etc. myself. One note, wear a good mask while sanding this stuff as it is very bad for your lungs.
