Scout Dana 44 prep for a CJ with Pics.
Kane
Full Time Jeeper
Berlin, CT
1984 CJ-8 Restomod Scout axles 4 wheel disks, 258, ax15, D300.
:)Kane, Good job & Nice writeup..........I am assuming you also cut off the opposite side spring hanger and repositioned it?..............and the only other thing I would have done would be to preheat the C's and tube........... just good practice to eliminate any cracks forming between the dissimilar metals while welding.
What is that Scout Wheel surface to Wheel surface width?
:D:D:D:D
Yeah I didn't mention the other perch but yes it just needs to be cut off and welded after the other side is ground down. I don't remember the wheel width off the top of my head but it was around three inches wider than a wide track CJ axle.
Excellent post! Thanks :D
What rear axle are you going to run with this Kane?
Thanks, very informative and thought out post. Pics really helped drive home the points. Great welds! Very clean.
I have a matching Dana 44 for the rear also from a scout II. They both have 3.73 gears. I plan to use the Dana 30 outer assembly for the front end and stick with the bigger drums from the 44 for the rear. I am only runner 33 inch tires so these will be plenty of axle even with my V8.
TCase Dana 20
