Engine Serpentine Belt Issues
BigBobola
Junction City, OR
1983 CJ7, 4.2L Straight 6, 4 Speed
Hello All,
So I put in a rebuilt AMC 258 i6 / 4.2l L in my 1983 CJ7 and now the serpentine belt keeps rolling off at the fan/water pump pulley, and the alternator is slightly crooked and further back than the other pulleys. I have tried various things like adding washers in places that looked like they were needed, new belt, nothing helps. All the mounting brackets, power steering pump, A/C pump, idler pulley, vibration damper, and water pump pulley are from the original 4.2 L. Has anyone else ran into this issue before, or does anyone know of an inexpensive way to align the pulleys?
Bob
Although I just re-read and you said serpentine belt. And mine is obviously not serpentine.
I suspect that the mounting brackets, especially for the alternator are not the same.
Probably not hard to convert, but I already have too much $ into my Jeep.
I passed that point way too long ago. And then I found the wires pushed through a stretch of garden hose for the passenger side tail light rather than dropping the gas tank and doing it the right way.
Oh, and the house wiring wire nuts instead of proper crimp connectors.
With the butchered engine bay wiring, I decided to just punt and get a Painless kit.
And then the "as long as I'm in there" bug took over.
Yeah nobody said Jeeps were cheap. They are cheaper usually than boats, and almost always cheaper than airplanes.
  100.0%
