Spacer between Carb and Manifold
pmeyers413
beaverton, OR
1977 CJ-7 with I6 258
Hey everybody! I'm hoping somebody out there can help me out. A little bit about my jeep, I have a 1977 CJ7 with an AMC 258 i6 / 4.2l I6 engine, also the carburetor is a 1BB Carter. I took my carb off the manifold and there was a plastic spacer between the carb and manifold. Well I misplaced the spacer and I can't seem to find one to buy anywhere! My questions are, what is it for? Do I need it? If I do, does anybody know where I can find out?
I wish I could help. Normally a NAPA store will have parts like that. I toss all mine when I put the 2100 on it.
I struggled finding a replacement myself. It is supposedly to act a as an insulator to prevent vapor lock. I ended up getting one for a Ford 2bbl. Most auto stores have a large book that has actual size gaskets and spacers in it and you just have to go through it until you find one that matches up.
I bought a phenolic one a while back off ebay but the guy was pretty proud of it.I wanted it to go on a Dauntless Buick 225 V6 v6 to try to stop it from vapor locking. it didn't seem to help any.
Thanks everybody! Definitely having trouble finding one. Does anybody know the name of it? Might make the searching a little easier. Thanks again!
I think I just put in something like " carb spacer"
I found this on ebay...it says its off of a snowmobile but it looks exactly like the spacer. Do you think it'll work?
type this in the search on ebay..if this is not the one you need,there is a number in the ad you can call and maybe they can help you out
Tri Power Intake Manifold Riser Small Rochester 2G Insulator Spacer Phenolic 1/4
compare the measurements that they list to yours..
