Spartan locker for Dana 30?
El Jeep o
New Mexico
85 CJ7, 258, T5, AMC20,D3O0,D30,Moser axle,4:56,MC2100,HEI,33" MT/R,2.5" SPRING CONVERSION
Thoughts on the Spartan locker for my front diff. (Dana 30 )
And correct me if i'm wrong but with the hubs unlocked, the locker should not engage/disengage at all...right?
What have you in the rear diff?
FWIW: I run D/L's front and rear.
Correct-Can't work if hubs unlocked.
open in the rear for now, i want a selectable for the rear. was thinking lunchbox would be good for front since it will only work with hubs locked...so in that sense it kinda is a selectable locker...kinda sorta
Yes-Detroit Lockers(D/L), front and rear diffs.
Get the rear done first.
I am quite sure Posi is running Spartan lockers front and rear on his 77 CJ7 he uses for the forum trail rides, Colorado and Moab. Dana 30 and AMC20 , and he crawls some difficult obstacles. I even helped install one.
i have a lunch box in the front ive run that for years now with no issues the rear im going to get a posi. i know its not a true locker but since my jeep is on road as much if not more than off the posi is better suited for that plus the slight slippage i get between disk engagements off road isnt enough for me to notice. the strictly off road rig im building will have selectibles front and rear.
LSD is a very good choice for 'snow-country', on or off road.
so all and all, if I go with the brand Sparten from USA gear. i wouldn't be making a mistake?
I can agree that living in snow country an lsd to be a good choice, but would have to suggest a quality unit at least. I had a Powerloc once and it just didn't cut it, so I went with a switchable locker for big bucks. From what I have read New Mexico has some awsome wheeling areas.
Edit: BusaDave wrote an article a while back that might be of some help:https://www.jeep-cj.com/forums/f105/lockers-limited-slip-differentials-12434/
With the Sparten-You depend(pray)the stock carrier can hold up.
With a Detroit Locker, you will never need to worry.
Ok Lumpy you almost got me convinced to go with the D/L. i dont like breaking stuff on the ol' jeep and ive had others tell me a lsd is more "gentle" on components. what about the set up or install should i say?
Gear pattern and backlash check will be the same for any new carrier.
If you have not done R&P work-Get a pro to do, it and watch what he does.
I say that as someone who has 50+ yrs experience setting up R&P's.
Would also be a good time to replace the front axle U-joints and axle seals.
Still-I'd do the rearend, before the front.
A D/L in the back end does takes a bit to get use to.
And if you go this rout stay off snow covered streets or you will find your back end wanting to pass the front end.
I'm a bit late to the party on this thread, so I apologize. But you might consider a Truetrac. Shares the benefits of an LSD with the true locking of a typical locker, but with out the noise or unpredictability of some other offerings.
TCase Dana 20
