specs for go devil??
IOPort51
Featured
Garland Texas
1977 cj-5
2006 Toyota Tacoma
anybody have torque specs and bearing specs for a 134 "L134 "Go Devil" " 4 banger?? is there such a thing as a FSM??:D
Besides A Factory Mechanics Manual Yearly there is a :
Service Manual For Universal Jeep Vehicles CJ2a - CJ6 & For Dispatcher DJ-3A
By : Original Reproductions
P.O. Box 5161
Newport Beach
California 92662
Camshaft Gear to Cam 30-40
Camshaft Thrust Plate 20-26
Connecting Rod Cap 35-45
Main Bearing Caps 65-75
Clutch Ball Stud 5/16" 35-45
Clutch Ball Stud 9/16" 70-85
Crankshaft CW Bolt 60-70
Cylinder Head 60-70
Engine Mount Cent Blt 45-55
Exhaust 29-35
Flywheel 35-41
Generator Bracket 25-35
Intake 29-35
Oil Pan 9-14
Piston Pin 35-41
Spark Plugs 25-33
Starting Motor 20-25
Valve Cover 7-10
Water Outlet Elbow-Head 20-25
Water Pump 12-17
Engine to Frame 10-15
Engine Rear Mount 20-30
Pressure Plate 12-17
P.S. On theCJ2APage.com forum I downloaded this PDF Manual & Owners Manual I already have. If you do not go to site & download and want them let me know and I will send to you.
I have an original manual if you need info as well.
Reprints should be available as well. Better realy so your not over handling a vintage piece.
originalreproductionsllc.com
Sorry gave the address off the manual, the web site says P.O. Box Yuma AZ.
The Mechanics is $45 Loose Leaf 3 Hole.
The Universal is $44.95 Bound
The Owners is $22.50 Wire bound
The Parts List is $25.00 Loose Leaf 3 Hole
And this is from the horses mouth, so everyone gets it from here (Walk`s, Kaiser/Willy`s etc..) 1941-1984.
The Universal PDF is 57,325kb in 1 file and when I get time I am going to put it in Adobe Pro and section it, when I get the time. Waiting for theCJ2APage to PDF the Mechanics Manual. I love having a computer image to save my paper.
1 week, 5 days, 8 hours, 55 minutes, 10 seconds
