Speed ometer question
maniacmoose
North Carolina
1979 cj5 golden eagle. AMC 304 v8. Edelbrock 600. Dana 20. Currently original wheels with crappy tires...looking to upgrade to a classic style with some 15" Mickey Thompson classic lock and 31" General Grabber Red Letters.
Thanks. I went back outside to look again and its just the screw cap and the needle. No gear. Is it possible that the gear is stuck inside the Transfer Case ?
The gear is inside to Transfer Case , and it appears a bit more complicated than I thought. I would suggest that you search online and search this forum for more info or someone else with a Dana 20 t-case can chime in. I was able to correct mine by a ring and pinion gear change.
