Speedo cable oil leak
racecar882
Visalia, CA
1946 Cj2A, 153 Chevy, T14, 18, flanged 44, 1963 Willys Wagon, Buick 350, T400, 67 Wagoneer frame, flanged 44, 1957 CJ5, 327, T15, 18, OD, flanged 44
Does anyone know the best way to stop a oil leak at the speedo cable attachment on Model 18 Transfer Case ?
New o-ring on cable side or you can make a gasket.
I think they came from the factory leaking .LOL. Don't know of a o-ring on that piece. On the positive side I found a fix for the cable leak on both my dana 18's.This involved machine work for a o-ring and a valve stem seal.
No more leak!Kinda hard to explain here but it involved a metal lathe and brazing the grooves in speedo gear shaft closed.I believe the problem comes from Transmission gear oil draining down to Transfer Case and over filling it.Next time I have it apart I will install a sealed bearing on the main shaft (output) That is a old fix and I just forgot to do it.:eek: Mike
