Sport bar
Germy
Full Time Jeeper
- Cincinnati, Ohio
- 1985 jeep cj7 360 20 rear and 30 front w/warn lockers 5 speed tranny,
1971 dodge dart built 318
Noticed that bar is not bolted down in the rear. Should I just drill and bolt? Just does not seem to be a sturdy platform. Is there a plate or bracket that should be?
I am looking at the OR-FAB CJ7 weld in sport cage #82086 or the YJ #82095 bolt in to tie into my YJ cage. I am waiting to hear from the OR FAB tech line to see if the bolt in kit for a YJ will bolt into my CJ with the YJ rear bar. I'm concerned about the bolt pattern where the YJ kit ties into the dash. I like the idea of being able to unbolt the front sport bar from the back half of the cage like the YJ kit does. Once the CJ weld in is installed it would require pulling out the entire cage (front & back) just to get the dash panel off if I ever need to get behind it.
