sr4 and t4 interchange?
cass
Kansas
1980 Cj5, 350 chevy (i built myself), T176, Dana 300, stock narrow trac 3.54 axles, locked in the rear, power steering, power brakes, tilt steering, Warn lockouts, 31x10.50x15 AT's, hi lift jack mounted on the front, bed lined tub, firestick cb setup, 5 in hella lights, NO RUST!!
my CJ5 has a SR4 . i found a T-4 on craigslist for AMC 150 bucks. will it bolt right in place of my SR4 ? i see on novak its compatible with AMC I4 & I6 engines. i have a 2.5 iron duke. will this work?
Same size and should interchange. Both are light duty transmissions
The T-4 if from a 4 cylinder 2.5L AMC powered Jeep will have a 1" x 14 spline input shaft, if it was from a 6 cylinder Jeep it will have the standard 1 1/8" x 10 splines. The clutch disc on the 4 cylinder is 9 & something inches diameter, the 6 cylinder clutch would have been a 10 1/2" disc. When I swapped to a V8, I changed the Transmission years ago to an Advanced Adapters WC Super T-5 that was built for a V8 to 350 HP and used the Iron Duke bellhousing off an SR4 Transmission for direct fit replacement of the 4 cylinder AMC bellhousing that was on a T-4 originally behind the AMC 4 cylinder I had. Everything is over the counter parts clutch wise and you can order it for stock applications by telling them the spline count so YES, IT IS A DIRECT BOLT ON APPLICATION..
i found one even closer. 10 miles away and 100 bucks :) i will go stronger when i break this tr4. lol thanks for the info man!
Thinking on doing the same swap. But i am removing the iron duke for a TBI 4.3 and wanting to keep my Dana 300 . will the T-4 have the strength to hold up to
33s and the power of the 4.3? does or has anyone done this ?
not sure if it will hold up or not but it is a light duty tranny so i would recomend a beefy tranny behind that motor. they run good for a v 6
well i ended up getting a T-4 . it was a direct bolt in. i had to make a shifter because they are different. other than that it was smooth as butter and works good. shift pattern is different for reverse as well.
