Stabbing the dizzy
Stabbing the dizzy
Germy
Full Time Jeeper
Cincinnati, Ohio
1971 dodge dart built 318
I am cranking till finger blows off the number one plug hole. I then stabbed to get the rotor to number one. It just VTRs is, no fire though. What am I doing wrong?
Thanks all!:confused:
The position does not have anything to do with weather you get a spark. If you were out of position,180*, and had a spark it would backfire through the carb. I would suggest you check your ignition wiring. first question , do you have 12V from the switch to the coil??:cool:
It must be to early in the morning for me, what does VTRs mean.:confused:
As IO said it should have fire no matter where the dist. is set.
You're 180 degrees out.
Bad coil, one of the posts (+) is cracked halfway down.
$135.00
  67.5%
