Stalling. Help Please!
Gdog
Ok, I have owned a CJ for a month. It is an 84 CJ7 with a AMC 258 i6 / 4.2l straight 6. I think I messed up and needs some help.
Yesterday I power washed under the hood so I could track down a small coolant leak, and it was covered in years of dirt and grime. I thought I let it dry sufficiently, but when I went to take it out last night the belts squealed when I gave it gas.
Then my real problems started. It stalled out backing out of the driveway, and at the stop sign at the end of the block. I took it back home, and it ran fine as long as it’s getting gas, but as soon as I had to stop it died. I started it up this afternoon, and it will star no problem, but will die as soon as I let off the gas.
Two questions:
1) How bad did I just screw up?
2) Any ideas what might be causing this problem and how to fix it
Thanks,
Two questions:
Thanks,
