Misc starting issues'
Frito Bandito
Salisbury, NC, USA
'84 cj7, 4.8, manual
My Jeep ('84 CJ7 Renegade , new AMC 258 i6 / 4.2l , rebuilt Transmission ) has been running great. Still have issues with fuel gauge although it is new and the sender from the tank is new, and the temp gauge isn't working. I thought it may be ground issues (it is a jeep). Well in trying to check grounds last night, something has gone wrong. When I go to start it, it will turn over, and over, and over but won't fire up. Fuel is reaching the carb. I put a tester light for the fire to the plugs (on a couple of different ones) and there appears to be no fire going to the plugs. Any ideas what I could have messed up? May be a short, don't know, but it is my main transportation right now as my adult kids are using my truck.
Check the coil and connection. I had one die this year for the first time. The primary was good, secondary was bad.
My Jeep ('84 CJ7 Renegade, new 4.2, rebuilt trans) has been running great. Still have issues with fuel gauge although it is new and the sender from the tank is new, and the temp gauge isn't working. I thought it may be ground issues (it is a jeep). Well in trying to check grounds last night, something has gone wrong. When I go to start it, it will turn over, and over, and over but won't fire up. Fuel is reaching the carb. I put a tester light for the fire to the plugs (on a couple of different ones) and there appears to be no fire going to the plugs. Any ideas what I could have messed up? May be a short, don't know, but it is my main transportation right now as my adult kids are using my truck.
Did you have power applied at anytime you were checking grounds or was the battery disconnected? If there was power it's fairly easy to create a feedback short by removing a ground.
Do you have any spare modules / equipment and what specific ignition system are you currently using?
I by passed the ignition switch ran power direct to the hei via a switch, works perfectly.
Battery was on, trying to do a quick check to see if I put in a new ground the gauge would work. Not a great idea. It is the stock setup for the ignition system. No spare modules, may check the coil and put in a new module.
I'm hoping that a direct to ground path wasn't created but it sounds like it happened.
Jeep ground systems are notoriously sensitive.
How long does your Jeep sit between start ups?
Replace the coil with a screw terminal type.
That OEM horseshoe connector has a long history of connector issues.
Is the choke correctly set?
Okay, I’m new to the site and hope I am asking this question in the right place and forum. I have a 1983 CJ7 that came from the Toledo factory installed with the AMC 4-cylinder engine. I know, those didn't show up until 1984, but what can I say? Even I was surprised when I picked up the Jeep in fall of 83 after returning from a tour of duty in Germany.
I've kept the Jeep virtually stock except for adding a Weber 2barrel Carb about 4 years ago. Its been running great. Good pickup, especially for a 4 cyl. A few weeks back, it was hard to start, finally caught although running rough. I turned it off and it remains dead. I replaced the ignition module as that was usually the culprit in the past. No go. I traced the system and all wiring is good. I did a nutter bypass a half dozen years ago and it's been running great. I have a lot of new spare parts so I started by replacing the coil, coil connector, solenoid (even though it turns over great) plugs, cap, rotor, and the pick up coil in the distributor. Bottom line, no spark at the plugs. I used one of your threatpds and checked the power to the ignition module and that is fine. I probed the coil connector with a test light (bulb, not LED) and the red wire is bright when in run and start. The green wire is very dim in Run, and I get no light on the green wire in start. Knowing the ignition modules are notorious for being bad out of the box, I installed a second new spare. Still no spark. I'm stumped. Suggestions?
