Wiring She won't start. So far I've gone down the line in the TSM
Turbogus
Old Time Jeeper
Featured
Albany, OR
'78 CJ 5 Renegade (Black Betty) Motor AMC 360, T150 trans, 20 tc, Dana 30 front and Dana 44 rear w/posi
'96 GMC K1500 Suburban (Big Blue Basterd) fully loaded with over $10k in options
Yes from last year, perhaps I should try Starting Fluid?
Knulla she won't turn over at all now.
Vittu Minua, I forgot to ground the Starter Relay when I was going at her again.
I had a similar situation where my aftermarket Howell TBI system just completely died on me. It wouldn't crank or turn over. It wouldn't do anything. I replaced almost every part on that kit including putting in a new ECM, and rebuilding the TBI, but nothing worked. Eventually I just ripped out the whole thing, and put in a 2bbl carb. You may want to consider pulling out all that aftermarket Teamrush stuff, and go back to a factory setup.
I had a similar situation where my aftermarket Howell TBI system just completely died on me. It wouldn't crank or turn over. It wouldn't do anything. I replaced almost every part on that kit, including putting in a new ECM and rebuilding the TBI, but nothing worked. Eventually, I just ripped out the whole thing and put in a 2bbl carb. You may want to consider pulling out all that aftermarket Teamrush stuff and going back to a factory setup.
I agree. It seems the Team Rush stuff may be the issue. The electrical system for the CJ is not that complex in and of itself, but with modifications, which I’m guilty of, things start to get complicated and result in all sorts of problems.
You made an earlier note about using starting fluid. I encourage you against it. I ruined a valve using starting fluid. I know many will balk at this, but I use a large syringe with some good old gasoline. Just a few drops does the trick and avoids the damage that starting fluid could cause. Back in the day, with M151 Jeeps, we gas-ragged them, but I also had the hair burned off my arm more than once.
I went down the MSD and Holley rat holes, all one company. I’ve had a few people tell me to ditch the Sniper since I have had trouble with it and the MSD stuff. “. Get the Howell. “ they have said, and hearing your story and others just frustrates the :dung: out of me. I did ditch the MSD ignition and went with an HEI DUI distributor. while also changing out a collapsed lifter and timing chain and sprockets and changed location of O2 sensor to Holley recommended location and also getting a bad Bosch O2 sensor also, and changing that out, I’m starting to think maybe I might be making my way back out of the Jeep abyss. Just to hot out this time of year to take a long drive for a good test.
thanks so much fellas. I really appreciate your input. :giggle:
Today while I was out to Physical Therapy I stopped by NAPA looking for a Fuel Primer Bottle. Heretofore, I was pouring old fuel into a carb cleaner lid and clumsily adding fuel to the primaries. At NAPA all they had was an oversized Battery Filler so I figured if it's impervious to battery acid it should be okay for fuel. In a little while I'm heading over to VP fuels to pick up a gallon of 110 Tetraethyllead Gasoline and in the coming days I'm back to work so the trial of squirting fuel down the primaries of the AFB will have to wait.
As a sidebar, I'm still running the Ford EEC-1 Ignition Control Module that was stock on 'Black Betty'
I may have been a little rough handed when I last adjusted the floats and I understand that it takes more finesse than that. I hope to get to it in the coming days.
Okay the new skinny (not me you understand) I come to find that I was ham handed when I last went into that Carter AFB and the floats were maladjusted as I initially looked online for the specification. As JeepHammer said years ago, free information is exactly what it's worth. I then put another Starter Solenoid into play and she fired right up. Retrying the Blue Streak and it was a dud, likely on account of me not holding the inner nut firm while tightening the cables. I found my Irwin Vise Grip needle nose pliers were just the thing. She starts on first try now but in my exploration I have a bunch of wiring laying on the right Header. I've got a few wire coat hangers to suspend those wires but I think there may be a more elegant way. Does anyone have any ideas?
Thank you Odd Fire, I determined that my heavy hands had tightened the Battery and Starter nuts too tightly, and managed to bend the interior contacts. Since wiring in an Echlin it's firing right up.
