stealth hei done
stealth hei done
dalefan88
Crazy Sr. Respected Jeeper
ada,oh
79 cj5 258, t150, dana 20 transfer case, dana 30 front, 20 rear,warn hubs,2.5" procomp lift,teamrush,msd box,mc2100 carb,hedman header,clifford intake,optima battery, ford shock towers.
finally got it done. since i have nothing better to do. i torn into the module. baked it in the over. got all the crud out of it and mounted the gm module in it. the wife went out and put it on. took a minute for her to fire up. when she did she was purring. i say it was a good switch. the gm module is alot tuffer then the ford one.
Is this so that if someone looks they think it has the stock ford module?
yep gutted the ford module, drilled the holes to mount the gm module in it. the only way you can tell something is different it the two screw heads on the top of the ford module housing.
