steering wheel problem
rr41mag
Full Time Jeeper
Panama city florida
04 dodge truck, 1966 chevy truck, 2012 rav4
And finally a 1981 jeep cj7 258 hardtop
I have a Grant steering wheel on my Jeep. With the inner snap ring holding the steering shaft tight to the inner bearing, it shouldn't change the length of the shaft. Are you sure all the parts below the steering wheel are in the correct order? With mine installed shaft length did not change.
The shaft inside the column is meant to collapse just like the intermediate shaft.
What may have happened is that when you mounted the wheel, you pushed the shaft together shortening it.
If you stood the column on end and applied pressure when you installed the wheel, you pushed it in. Try to grab the splined end ( the end that went away) and with out damaging the splines, slide it back out enough to install the intermediate shaft.
