Still workin' on that carb issue, but a new wrinkle
Turbogus
Old Time Jeeper
- Albany, OR
- '78 CJ 5 Renegade (Black Betty) Motor AMC 360, T150 trans, 20 tc, Dana 30 front and Dana 44 rear w/posi
'96 GMC K1500 Suburban (Big Blue Basterd) fully loaded with over $10k in options
So last week I'm down at NAPA to get a new plug socket, (the old NAPA branded one I had lost the rubber inner sleeve) they no longer had NAPA branded plug sockets but they warrantied this with one by the Carlyle line. I noticed that the rubbet inner boot opening was larger and didn't hold the plug by the ceramic sleeve but by the tip of the spark plug instead.
Tightening down the no. 6 & 8 spark plugs on my 360, you know, the two that you have to access from under the CJ's, and I heard the ceramic crunch and sure enough the ceramic was broken. I thought that I may have pulled at the odd angle one has to address those no. 6 & 8 plugs was the reason. Gingerly I tightened down the others on 2 & 4 and moving to the plugs on the left bank no. 7, (that I had a straight, clear of obstruction shot at) also crushed the ceramic on the plug. I'm not new to changing spark plugs on my Jeep but this is getting right infuriating, considering that my trusty old NAPA plug socket never once cracked/broke the ceramic on any plug on the various AMC, Ford and Chevy's I've used it on.
Do y'all reckon this is just a bad casting or a design flaw?
Tightening down the no. 6 & 8 spark plugs on my 360, you know, the two that you have to access from under the CJ's, and I heard the ceramic crunch and sure enough the ceramic was broken. I thought that I may have pulled at the odd angle one has to address those no. 6 & 8 plugs was the reason. Gingerly I tightened down the others on 2 & 4 and moving to the plugs on the left bank no. 7, (that I had a straight, clear of obstruction shot at) also crushed the ceramic on the plug. I'm not new to changing spark plugs on my Jeep but this is getting right infuriating, considering that my trusty old NAPA plug socket never once cracked/broke the ceramic on any plug on the various AMC, Ford and Chevy's I've used it on.Do y'all reckon this is just a bad casting or a design flaw?
