Strange no start this morning
Turbogus
Old Time Jeeper
Albany, OR
'78 CJ 5 Renegade (Black Betty) Motor AMC 360, T150 trans, 20 tc, Dana 30 front and Dana 44 rear w/posi
'96 GMC K1500 Suburban (Big Blue Basterd) fully loaded with over $10k in options
The readings are closer to ideal but the Coil was not the exclusive issue. Got through Chart 1 Step 4 of the DARS last night, Voltage remained at 10.4V after removing the "I" terminal. I then connected a jumper from the Negative side of the coil to the negative battery terminal and I did get voltage drop to 5.7V.
Moving on to Step 5 checking the continuity between the new Coil negative terminal and D4 on the four pot Ignition Module and it took some serious probing force but I did get solid continuity.
By the DARS chart the next step is to replace the Control Unit i.e. Ignition Module.
I got on top of the motor last night with the help of a step ladder and noted that Pump Jets (accelerator pump) were supplying fuel to the primaries on the AFB.
If I can find the time going to act of JH's recommendations of checking TDC.
I'll continue posting results here as the occur.
Gus, prior to the no start issue, was there any misfire on the ignition? That would be an indicator the icm was going out, but they can just die anyway. What brand of icm are you currently using and does it have the black ground wire from it directly grounded to the battery? Some guys just attach a ground wire to the black wire from the distributor and others just disconnect it from the dist. and attach it to the battery. I use the Echlin brand of icm and it seems to work quite well, but very pricy.
It looks to be the original Ford Ignition Module. I was just reading about John Strenks' Stealth Upgrade, but it's to technical for the likes of me (ie my housefrau won't let me use our oven. :eek:
Remove the distributor cap and spray in some WD-40. If it makes you feel better (I would) wipe out the excess. Put her on and Go for a drive. You Jeep was running well, suddenly she don't run well, but everything checks out. My first thought would be condensation in the distributor cap...........
