Swapping '79 304 for '74 304
thistle3585
- IN
- 1979 Jeep CJ5 with '72 304 V8, MC2100carb,T150 trans, AMC20 rear diff with locker, Dana 30 front diff, Dana 20 Tr Case, Procomp Springs, Gabriel Ultra shocks.
I am replacing my blown AMC 304 in my '79 for one that came out of a '74. Obviously, they had two different emissions setups, carbs and a few other things different. I was going to use just about everything off the '79 AMC 304 on the '74, but I wondered which is the better carb to use. This is a daily driver around town and my choice is the '74 Holley or '79 MC210? I guess once I make that decision then I will start to look at the emissions setups, vacuum lines etc. based on the carb I choose. Also, the exhaust header on the '79 comes together right off the engine and into a single pipe whereas the '74 header is four separate pipes that go in to a collector located below the engine. Is one better than the other?
