T150 Rebuild
T150 Rebuild
mfikes
Keller, Texas
'76 CJ-5, 258
Hello all,
I hit the wall early with this one. Using FSM to rebuild my T-150 . Everything is great until I need to remove the clutch shaft. It calls for a bearing remover tool J-6654-01. Never seen one - Can't find one. And I'm afraid to pull te bearing because it says to remove shaft, front bearing and 2-3 synch blocking ring as a unit.
Has anyone else run into this? What to do:confused:
Also, please let me know any other tricks I'll need to overcome the 'obsolete tools' issue. I already got the dal-rod = arbor tool one.
Check out that thread and let me know what stage your at by looking at the pic's.
I can help ya out. I had no bearing removal tool. And rebuilt mine sitting on the
garage floor.
Welcome to the site, BTW!
Welcome!
Once you remove the lock ring you can fit a chisel into the grove and use it (along with a hammer) as a lever to pry the bearing out of the case.
The whole thing will come out as a unit.
The photo is from the CJ Rebuilders Manual, great book tons of good info.
Welcome!
Thanks Jasper. I appreciate the reference too. Looks like I need to get the Rebuilders Manual.
I looked for that Novak page (I know I've seen it before) but couldn't find it.
I talked to someone at quadtratec who told me to modify a 4" bearing splitter by using two long bolts or threaded rod. Clamp the splitter in the groove and use a puller to extract the assembly. It looks like that would work. If not I'll try the hammer and chisel approach. Can't get to it until Sunday, but i'll take pics and report back.
I did the hammer and chisel and it came out almost without effort. It is not as tight as say, a ball joint.
You could always hit it with BP Blaster first as well.
TCase Dana 20
