T18 t19?
T18 t19?
BrockGrimes
Jeep-CJ.com Archive Master
Kathleen, GA
ON THE HUNT AGAIN
Why go with a T-18 when a T19 as I understand it is the same thing but 1st and reverse are synchronized?
Opinions? other info I'm missing?
The reason I went with a T-18 is availability and the 1st gear.
What I did want was the 6.32 first gear, good enough for me down here in the south (no rock crawling) with my Dana 20 , mud and trails are what I'm running in. The 5.11 in the T19 kinda turned me off, just not low enough for me when I would be in 1st.
Mines being built for rockcrawling also , hence the T-18 . 2nd through 4th are pretty much like a T-150 3 spd then.
Per Novak's site:
"The Ford and some Jeep T18s enjoys a very low compound gear at 6.32:1."
"T19 versions offer a 6.32:1 (IH), 5:1 or 4:1 (Ford) low gear."
The only difference I find is the T19 has synchronized 1st.
Exactly right, the t19 IH is a pain to find and unlike the Ford needs parts swapped around, I wasn't into that...
I have a T-19 out of a '79 ford truck w/ 6.32 low I rebuilt for my Scrambler. The benefit of syncos in 1st gear are questionable. You have to be going so slow anyway.
Hello Longhorn and welcome to the site! :chug: That is one nice CJ8 you have there in the gallery. Glad to have you on board!
Thank's CJ, not much Jeep left. Mostly other parts now. :D
What motor are you planning to run?
i have a muncie M-22 "Rock Crusher" and have no probs with mud or crawling rocks...never experianced any of the T-18 or 19's though
Want a T-18 ? I have the ford version with 6.32 1st. pm me if you do.
Per Novak's site:
$20.00
  10.0%
