T5 quick help
Germy
Full Time Jeeper
- Cincinnati, Ohio
- 1985 jeep cj7 360 20 rear and 30 front w/warn lockers 5 speed tranny,
1971 dodge dart built 318
I drained the T-5 . Took out the fill on the other side above the electrical connection. Turns out this was not the fill hole. The bolt came out but was not what i was looking for. Found the real fill hole and filled it. The other bolt on drivers side has a step down to the end. We wiggled and got the bolt in but finally realized that only 1,2 and n work but neutral to the passenger side and 4,5, and reverse dont work. We retried and got it all together. Started it and it grinds when clutch is released in neutral.
Is there a special order to installing?
Thanks in advance! Im stuck at my buddies
