TBI Woes
Techlight
- Media
- 1
- California desert
- 1984 CJ7: 4.2l i6 (mild cam), Team Rush, Howell TBI, T5, D300, D30-front, AMC20-rear, 33/10.5/15 BFG A/T's........................
1964 Kaiser CJ5 (sold),
1960 Willy's CJ5 (sold)
Hi All,
So I took the jeep out and was splashing in some puddles a few weeks back. Motor started to get wet and so I parked it. When it was carbureted it would always dry out and no problems. The Howell system seems to have freaked out.
It's running rich it seems to me...alot of wet fuel coming out of the tail piple and black carbon and the mechanic said it was running rich (more on this in a minute). It's throwing code 12 and nothing else. I'm checking it with the jumper and watching the light flash. It bogs down if I step on it and then kinda lurches forward. It's generally running rough like the timing was off or something. I parked it for awhile and then my Honda was stolen (again) and so i need the jeep.
I checked for vacuum leaks and intake leaks but found none. I took it to a reputable mechanic in my area and they had if for 5 days and were back and forth on the phone with Howell and they ended up giving it back to me because they couldn't figure it out.
They checked: TPS, MAP, O2, IAC, timing, dist play, back pressure, engine temp, fuel pressure. All supposedly good, but it's still throwing code 12.
Any ideas or help would be great...or if you know a good mechanic in the Lancaster CA area.
The motor is a reman stock with a mild cam. About 8-10k miles, Howell CA TBI, and the Team Rush Ford cap and rotor. The rest is all stock.
The system used to run great when I put the TBI on but since I doused it it's trashed. It also has a bit of a hunting idle, like it's going to stall and then jumps back up before leveling out again. It's always done this though even when it was carbureted.
Thanks much...
Thanks much...
