Electrical Temp gauge issues
Sounds like a grounding issue.
Hope you didn't use Teflon tape on the sensor.
Also, run a hardwire lead from the dash panel to the battery NEG(-)post
I've been installing digital gauges in my old vehicles. They are cheap (around $10 on ebay) and are pretty accurate. Plus they can be used as a fan switch. Why guess?
Digital Temp Controller
What Lumpy said...
If it's not that, the gauge is probably no good...especially if it's a Crown or Omix replacement (can't see your vid)
Have had two that were bad out of the box
