TF999 dip stick length? look what i found
83power
Sudbury, Ontario
1983 CJ-7
258 Inline 6, 4.2L
Automatic
I'll get it for you but I'm at work till 7:00 pm. If no one else responds look for a pic with the measurement around 8:00 pm
TF 999 is a Chrysler Transmission , light duty Torque Flight 999/904(older version) it has the lower first gear in it, not positive but you should be able to hit up any junk yard with older Dodge trucks and get a dip stick. The dealer still sells them and also Lokar makes a braided steel one.
***** Torque Flight transmissions require that the kick down linkage be attached and properly adjusted, failure to do so will burn it up in about 200 miles***** (it will think it is still in park and not apply enough fluid pressure to the clutch packs inside) ask me how I know :cool: BTW your filter and pan look pretty clean as long as the fluid didnt smell burnt thats probably a good tranny, by the time I crack several of mine open they where way worse
