TF999 with Dana 300
TF999 with Dana 300
MJT77
CA
Hey guys,
I am starting to go through my new to me 79 CJ7 . It has an AMC 360 mated to a TF999 with a Dana 300 . The PO did the drivetrain swap and I'm not sure if he did it corretly. Aside from the Marie Callenders pie tin covering the old manual Transmission opening, He cut the floor in order to make the transfer stick fit. Not only that, but it seems that the Dana 300 hangs down pretty low for my taste, but it's mostly due to the Transmission . Is this typical?
Is a T400 any shorter or narrower that would allow the Transfer Case to be raised a little?
I will try to post some pics once I figure out how.
post some pics if you can. thats the same setup my po did. if i can see yours, ill be able to tell if mine is wrong or yours, as i have nothing to compare it to
That doesn't look like a Dana 300 to me.
I'm not an expert on identifying things yet, but the case is stamped with Dana with the number c300-15-2. I'm pretty sure that's a Dana 300 .
I cant identify the transfer but it does seem to be hanging down kind of low.
i do think it hangs down to low as well. mines not that low
My combination consist of a T-18 from a Ford F-AMC 150 with a Novak conversion to mate it to my Dana 300 . In my case, the adapter allows the Dana 300 to be clocked at different angles. It may be that your Dana 300 and Transmission might have that same ability. I would take a look at where the two mate and see if there are more mounting holes that are not used. Just a possibility.
Y
Doesnt the Transfer Case go up a bit when you put the skid plate back on? I just got rid of the rest of my Jeep that had that combo and the Dana 300 always hangs a little low i.m.o. There are clocking rings out there for a price.
Alright, finally got some pics. Let me know what you think.
