Hello,
I have completed the Team Rush upgrade in my old 83 CJ7, I-6.
I do not have a Ballast resistor.
First ICM was the original, so I thought it was just old and failed.
The second one was brand new and it has failed as well.
Both got hot and then failed.
I realize the upgrade increases the power in the entire system, but there must be something else I can do???
Is the BALLAST RESISTOR a must ???
OK, some 'Clarification' here...
There isn't a 'TFI' upgrade that I know about.
No one is using the Ford TFI module mounted on the side of the Ford distributor.
We DO use the E-core coil from the TFI ignition sometimes, especially when you switch to an HEI style module...
Sometimes called the 'John Strenk Steath HEI Swap'...
Now,
*IF*...
You swapped to an E-core ignition coil (Ford or GM style external coil),
That particular coil has LESS RESISTANCE than the factory Canister Coil.
That INCREASES the current the module has to handle, and often causes the old factory, or almost worthless 'China' modules the discount 'Sores' sell to fail regularly...
SO...
John Strenk came up with a 'Stealth' swap so you can run an HEI style module that works with the E-core coils better,
And it doesn't show, so you don't get popped at the 'Emissions Visual' inspections.
You simply GUT the case of the factory module, saving as much of the wire as you can,
And you use the aluminum case as a heat sink for a GM style module ($20-$25) that handles the higher current the E-core coil passes to the module.
Since you didn't tell if you have an E-core coil or not, I'm not sure this is your problem.
The cap, rotor, plug wires upgrades WILL NOT increase the load on the coil/factory module,
But the E-core coil swap WILL increase demands on the factory/'Replacement' modules.
The swap goes something like this,
The 'Capacitor' and 'Diode' are optional, depending on what ignition switch your vehicle has, and if you hear the ignition in the radio.
Capacitor is from an HEI, and stops radio noise,
Diode will stop the starter motor running 'On' after you let off the key switch.
Not all Jeeps are wired the same,
And since the parts stores no longer stock the early Jeep ignition switch, substituting the GM version,
The diode is sometimes needed to get the vehicle started and running and NOT have the starter 'Run On' when you let the key switch return to 'Run' position.
With this module conversion, you DO NOT need an ignition resistor of any kind, you can feed that E-core coil with full line voltage with no issues,
Just make sure you get the module down on a good heat sink and use heat transfer paste under it, NOT dielectric grease that often comes with the GM style HEI modules.
Bypassing the factory ignition resistor wire is your choice.
Bypassing it adds just a little more to your spark energy, but in most cases, it's not necessary or worth the extra work.
The diode is Radio Shack p/n 276-1141 about a buck each usually comes in a two pack so you can screw up the first time.
