Build Thread The $120 Jeep CJ7 build thread
Fantastic wheel design you got. I am still holding on to my Centerline Outlaws from the early eighties. The bare brushed aluminum finish is timeless and not as popular anymore. I use that corrosive and dangerous acid to clean them every so often, and they look like new and flawless every time.
The CJ bolt pattern with the large hub hole yields Limited wheel choices. The need for larger wheel offsets makes it even worse. The Method brand is offering some decent choices with modern spoked designs, perfect if you want to show off your discs on all corners. They heard us, the “set in our ways” old timers.
I also find your “reverse” wrapped leaf springs interesting. Very favorable for your SOA.
Think that offset is going to look cool. Will you have to worry about inspection sticker or needing fender flares?
The CJ bolt pattern with the large hub hole yields limited wheel choices. The need for larger wheel offsets makes it even worse. The Method brand is offering some decent choices with modern spoked designs, perfect if you want to show off your discs on all corners. They heard us, the “set in our ways” old timers.
Not a CJ bolt pattern. Well, ok, it IS the same pattern, but the axles are off a Dodge truck. Full size Dana 44 front, Chrysler 9.25 rear. As far as Method wheels go, I just wanted something that would keep the military look. These wheels won't be shiny anymore once they get powder coated desert sand... I hope you can powder coat aluminum. I'm calling tomorrow to find out.
One of the reasons I go them. When I was looking at YJ springs for the SOA, I read up on the Rubicon Express ones, as they were designed for just that purpose.
I may end up extending the fenders a bit, not sure yet, but there's no inspection in my part of the state... only up in that corner of the state by Chicago. I guess they wanna be part of IL. I live in Indiana.
Anodizing your wheels might be a better option. Unfortunately it’s not simple to do it.
You are using Dodge axles and I am using Dodge Ram wheels on my CJ. May I ask what model year your Dodge axles are? I see that the pumpkin is on the passenger side.
That flat desert tan military color is fabulous. Great choice.
No clue on the rear, but mid 80s. They came on a 1980 CJ5 I got already built. When I went looking for a replacement housing for the front, it was from a 1983.
That’s one heavy duty tank.
$125.00
  62.5%
