Throbbing, pulsing clutch pedal
b3uhbp
Arlington, TX
84 CJ7, 258, T5, Dana 300, Dana 30' AMC 20' Weber 32/36 carb, DUI HEI ignition, 2.5" suspension lift
Recently I replaced the clutch on my CJ7 . Also replaced rear drive shaft and u-joints and Transmission mount. Everything seems to be working very well, but when the engine is running and I begin to push on the clutch pedal and the throw out bearing gently engages the pressure plate I get a throbbing/pulsing in the pedal. Once I fully engage or fully release the clutch it goes away. Wasn't there before. Any ideas?
No. But the pulse wasn't there before.
Sent from my LG-H810 using Tapatalk
Howdy neighbor :chug: sounds to me that if you replaced the clutch that one of the fingers on the pressure plate is slightly higher than the others and thats causing the pulsing as it rotates past the clutch fork, hard to say tho
Bent diaphragm fingers, it's easy to do when installing the Transmission . That's why I prefer the 3 finger type. But that's just me.
I think you're right. I thought the same thing. In thinking about what could cause this, that is the ONLY thing that makes sense. I'm not going to worry about it and will hope that as the clutch gets broken in the pulsing will subside.
Bent diaphragm fingers, it's easy to do when installing the transmission. That's why I prefer the 3 finger type. But that's just me.
Thanks man. I think we have a consensus. I can live with it and it's certainly not worth taking it apart again.
I concur with either bent or cracked/broken 'fingers' on the diaphragm clutch pressure plate.
Does the tranny shift OK or is the shifter need'n more effort now?
Who's clutch is this?
The tranny shifts fine. Very smooth. No other issues at all. It was a LuK clutch.
WOW-A Luk :eek:
I had 2 Borg & Beck fail like that.:mad:
Have a Luk in my Jeep now, and has been fine for many years...........
One thing I would suggest. Make the jeep safe and all that. Start it up crawl under her and lay your hand on the shift fork. If it is pulsing with the clutch engaged, even only a tiny amount your throw out bearing it still touching the clutch fingers. back it off until it no longer pulses.
HH has a very good point. :notworthy:
How much pedal freeplay do you have? You need to measure this, and don't guess. You want 1-1 1/4". No more-no less.....
I had a girl friend once who told me her clutch was throbbing or maybe she said it was pulsating, nevertheless, it turned out to be the brake pedal.
